defender-kris Posted January 3, 2012 Share Posted January 3, 2012 hi lad i have been trying to remove my clutch master cylinder but i am now stuck with the bottom 13mm nut witch i can not get at how do i access it ??? an help welcome thanks kris Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 3, 2012 Share Posted January 3, 2012 Easy look in the tech archive!...... There is a step by step thread, used it myself and it's bang on Quote Link to comment Share on other sites More sharing options...
simonb Posted January 3, 2012 Share Posted January 3, 2012 It easier to get out if you remove the complete pedal box - wear eye protection/googles 'cos as you press the pedal to wiggle it through the bulkhead it will squirt out a jet of fluid. Myself and a few others on here have had narrow misses.... Quote Link to comment Share on other sites More sharing options...
Reiny Posted January 4, 2012 Share Posted January 4, 2012 When you undo the hose connection, pack the area with a rag and give the pedal a couple of pumps. It'll get rid of most of the fluid. Quote Link to comment Share on other sites More sharing options...
