Arbman Al Posted January 15, 2012 Share Posted January 15, 2012 I have this wire flapping around at the back of the airbox, but can't see where it connects to. Any ideas please? Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2012 Share Posted January 15, 2012 if you cut some of the outer black covering off & expose the inner wires they may have a colour coded covering which might help ident the cable/wires on the wiring diagram, or trace the other end to see what it connects too. Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted January 15, 2012 Author Share Posted January 15, 2012 I think it was plain white or white/black and comes out of the engine wiring loom near where the MAF wires exit. Quote Link to comment Share on other sites More sharing options...
Dave W Posted January 15, 2012 Share Posted January 15, 2012 If it's near the MAF I'd have thought the Ambient Air temperature sensor would be the first one to check - the sensor is on the side of the air filter box, heater matrix side. Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2012 Share Posted January 15, 2012 I'd go with the above. Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted January 15, 2012 Author Share Posted January 15, 2012 If it's near the MAF I'd have thought the Ambient Air temperature sensor would be the first one to check - the sensor is on the side of the air filter box, heater matrix side. Hi Dave, Both connections are on the airbox and maf already. It appears it is the wire for the oil pressure sensor, as I have not connected that yet, and the strange looking connector at the end of the wire is the inside of the plug! Will have a closer look tomorrow.... Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted January 16, 2012 Author Share Posted January 16, 2012 Mystery solved - it is the wire for the oil pressure sensor, and even better the actual plug that is missing is on the sensor as well! Quote Link to comment Share on other sites More sharing options...
western Posted January 16, 2012 Share Posted January 16, 2012 good to read the mystery is solved. Quote Link to comment Share on other sites More sharing options...
