welling4x4 Posted January 23, 2012 Share Posted January 23, 2012 Hi All , I have got a warn X9000i, the fault it has is when you put it in free spool & run out the rope it's fine when U winch in or out under load, the brake don't hold & the drum just free spool out . Or when it's underload the winch does Not hold the vehical unless U hold the clutch / free spool lever in postion ??? any advice would be great. I have been told that you can take it apart & turn the cluch/free spool 180% & that would sort it out .Any ideas or fixes on the fault would be appreciated ??? Quote Link to comment Share on other sites More sharing options...
verminhunter Posted January 23, 2012 Share Posted January 23, 2012 Try this chap, most winches just need stripping down and a good clean and rebuild.. http://www.wanderingtrail.com/Repairs_Rebuilds/warn_winch/warnwinch.html Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted January 26, 2012 Author Share Posted January 26, 2012 thanks 4 the link. Quote Link to comment Share on other sites More sharing options...
