Astro_Al Posted August 15, 2006 Share Posted August 15, 2006 I've got an old Cebora Mig - big old thing, had a hard life making trailers apparently. I picked it up for free, well, I expect my former boss is still waiting for that 50 quid, but given what he paid me I don't feel too guilty! So... How do I keep it running nicely. I know I should remove the side panels and give it a hoover occaisionally - even I know that grinder dust conducts electricity. Also, clean the rollers and check the tension (I heard triggering the motor and increasing tension until you *just* can't stop it being pulled through is a good rule of thumb?). Obviously keep the torch, tip, shroud, earth lead etc in good fettle. What else can I do? There seems to be a problem where the solenoids (or whatever it is that quietly goes /bang/ when you press the trigger) sometimes just click on and off when I'm not using it - I guess its a maintenance problem - maybe carp shorting it out? The torch is new and my third while the welder has exhibited this problem, so it's not that. I love the fat old dino, so I don't want to 'upgrade' to some modern lightweight POS if I can avoid it... How can you be sentimentally attached to a flippin' welder...? Anyway - any suggestions regarding either my apparent solenoid issue, or welder maintenance in general? Ta Al. Quote Link to comment Share on other sites More sharing options...
minivin Posted August 15, 2006 Share Posted August 15, 2006 just wondering if the solenoid armature is retained by a spring and that has relaxed or rusted, allowing the contacts to drop and make contact without any input from the pistol grip, worth a look Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 16, 2006 Share Posted August 16, 2006 Could also be a chafe in the wire somewhere, a breakdown of insulation, or a bit of metallic crud across a contact. Crud like that can be "blown off" when it conducts, creating a very hard to trace intermittent fault although there should be signs of arcing nearby. Quote Link to comment Share on other sites More sharing options...
