icebear Posted January 27, 2012 Share Posted January 27, 2012 I have this rattling noise in the dashboard when selecting background light on the dashboard with the small light handle(pushed forward two steps), anyone have any ideas?? I opened the dash and found something I think is a relay marked rover 2012 rattling, is it easy to change or where can I buy a new one. Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2012 Share Posted January 27, 2012 which defender year/model have you got ? that info will definitly help. Quote Link to comment Share on other sites More sharing options...
icebear Posted January 28, 2012 Author Share Posted January 28, 2012 Its a 2002 Defender 110 Quote Link to comment Share on other sites More sharing options...
icebear Posted January 29, 2012 Author Share Posted January 29, 2012 Also when I select the long light with the long lever forward, It is not working, could it be somthing wrong with the contact points in the levers, or could it be a fault in the rattling box? Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2012 Share Posted January 29, 2012 the left column stalk won't operate the mian [full] beam if the short main light switch is only on side/tail light position. Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2012 Share Posted January 29, 2012 can you gain access under the rubber boot, as that NPN2012 doesn't show as a part number. hoping there is another label on the actual relay/control unit. Quote Link to comment Share on other sites More sharing options...
icebear Posted January 31, 2012 Author Share Posted January 31, 2012 I will check some more, couldn't find anythong om that number muself Quote Link to comment Share on other sites More sharing options...
icebear Posted February 1, 2012 Author Share Posted February 1, 2012 Been checking under the dash today, and took some more pictures, I'm not an expert but I think its some relays, it's marked Carlo Gavozzi M 25 S 001 012 16, BA 250V ACI 12VDC, 0429W, and is buzzing when selecting the full beam light in fixed position and does not give me full beam, when flashing it, its ok. Quote Link to comment Share on other sites More sharing options...
icebear Posted February 1, 2012 Author Share Posted February 1, 2012 Here are some pictures Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2012 Share Posted February 1, 2012 http://www.carlogavazzistore.com/Carlo_Gavazzi_Products.html is the makers website, look added items to me, is the vehiclle a ex-utility company or emergency services ??? Quote Link to comment Share on other sites More sharing options...
icebear Posted February 2, 2012 Author Share Posted February 2, 2012 Thanks, don't think so, it's just an ordinary Defender bought in Norway serviced by Land Rover dealers/garages. If I select the full beam on (pushing the long light lever forward) nothing happens, but I can flash with it, could it be 2 different faults, maybe it's t he lever and the contacts thats worn out?? Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2012 Share Posted February 2, 2012 sounds like 2 faults, maybe try a known good main light switch & a stalk to prove if they are the problem. the other unit could be for Norway daytime lighting, might be worthj asking your LR dealer about them. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 2, 2012 Share Posted February 2, 2012 two types of relays on that board, single pole changeover x2 and a double pole change over x1 and looks like a transistor on the underside. looks like an aftermarket fit to control the lighting. Relays should be relatively easy to source, i'd try the earth and the supply to make sure the relay coils are switching properly. From your description It sounds like relay buzz or chatter, can be caused by poor supply or faulty relay. Quote Link to comment Share on other sites More sharing options...
icebear Posted February 3, 2012 Author Share Posted February 3, 2012 Ok, I will check the earth(black wire?) and then go for a new light handle and see if that helps, thanks for tips. Quote Link to comment Share on other sites More sharing options...
icebear Posted March 22, 2012 Author Share Posted March 22, 2012 Changed the two light switches and everything works fine now. Quote Link to comment Share on other sites More sharing options...
