pitbull63 Posted January 28, 2012 Share Posted January 28, 2012 Has anyone got a pic of the series 3 bulkhead,dash off but showing where the heater outlet enters into the cab please? Mine has a tin box thing thats been siliconed onto the bulkhead(see attached picture) and 2 duct pipes exit it at the top.I,m sure that its not how it should be so any advice would be great. Thanks in advance Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2012 Share Posted January 28, 2012 this should help. http://www.retroanaconda.com/landrover/2010/03/series-iii-parts-book/ look in cooling & heating section. Quote Link to comment Share on other sites More sharing options...
pitbull63 Posted January 28, 2012 Author Share Posted January 28, 2012 this should help. http://www.retroanac...iii-parts-book/ look in cooling & heating section. Thats a cracking website Cheers for that but I,m still no wiser as to where the pipes go once through the bulkhead and into the cab Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted January 28, 2012 Share Posted January 28, 2012 S3 heater motor is behind the hole in the wing. There's a circle of foam to seal the 4 in gap to the vent. There's then a large diameter thin plastic hose (4 in diameter?) connecting it to the heater element box which sits roughly where the accelerator/brake pedals would be on LHD vehicles. This lines up with a squareish hole through both bulkhead skins. On the inside is the heater distributon box which is inside the crash padding - this runs across the dash and sprouts the footwell and screen vents - and it contains directional flaps above the footwell vents. Looks like the hole is behind that metal box. Quote Link to comment Share on other sites More sharing options...
pitbull63 Posted January 28, 2012 Author Share Posted January 28, 2012 Thanks for that.I think I know where things need to be now and I,ve got a bottom dash to pick up next week so hopefully things will get sorted then. Thanks to those that helped Quote Link to comment Share on other sites More sharing options...
