Paul Woodward Posted January 29, 2012 Share Posted January 29, 2012 I'm using the Td5 type rear fog switch and relay on my 90. Does anyone know where I can source a connector plug for the relay from? Google tells me that the same relay is used on the Rover 600. I've crawled all over and under 3 of them in the scrapyard this morning but couldn't find it in any of them. Alternatively could anyone look at their relay and tell me which colour wire goes to which pin? The pins on the relay aren't numbered so the diagram isn't much help. Black/Slate,- Switch. Black,- Earth. Red/Yellow,- Lamp and warning light. Blue/Purple,- Supply. Thanks for any replies. Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2012 Share Posted January 29, 2012 her's the relay socket viewed from above as the relay would be pushed in. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted January 29, 2012 Author Share Posted January 29, 2012 Thanks Ralph that's fantastic. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 29, 2012 Share Posted January 29, 2012 I'm using the Td5 type rear fog switch and relay on my 90. Does anyone know where I can source a connector plug for the relay from? Google tells me that the same relay is used on the Rover 600. I've crawled all over and under 3 of them in the scrapyard this morning but couldn't find it in any of them. Alternatively could anyone look at their relay and tell me which colour wire goes to which pin? The pins on the relay aren't numbered so the diagram isn't much help. Black/Slate,- Switch. Black,- Earth. Red/Yellow,- Lamp and warning light. Blue/Purple,- Supply. Thanks for any replies. The connector for the Rear Guard Fog Lamps ECU is a strange one. It’s a Sumitomo connector (similar to, but not the same as, their HMDC Series), but it isn’t in any of their catalogues or on their website. Although I haven't found a source for new connector shells, the terminals are (supposedly) available from Land Rover. Land Rover list the Terminal as a Genuine Part – Part Number YPL10003, but this has been out of stock since early last year. The Terminal/Tab size is 2.8mm so, at a push, you could use standard 2.8mm insulated female spade terminals. If you fancy a trip to the Breakers Yard, in addition to the Fog Lamp ECU found on Rover 600s and late-model Rover Minis, the connector is also used as the Indicator Switch Connector on the following – MG TF Rover 25 MG ZR Rover 45 MG ZS Rover Mini MGF (->2001) MGF (2001->) Rover 100 Rover 200 Rover 400 Discovery 1 Discovery II Freelander 1 . Quote Link to comment Share on other sites More sharing options...
western Posted January 29, 2012 Share Posted January 29, 2012 Cheers Paul, i had a feeling you would jump in on this one. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted January 30, 2012 Author Share Posted January 30, 2012 Thanks Paul, looks like another trip to the scrapyard then! I was going to use 2.8mm spades but it would be nice to have the right thing. Quote Link to comment Share on other sites More sharing options...
