TD5 Wiper Wheelboxes
Apart from the cover can these be dismantled ie removal of the spindle?
I recently bought a new genuine pair of these but I'm not too happy with them. One of them feels a little tight to turn and the other makes a terrible squeeking sound when you rotate the spindle as if its bone dry and needing greased.
no need to remove the gearwheel it's swaged on IIRC, just turn the gear 180 degrees to use a better condition part of the gear, but it rotates as the drive cable is threaded into the tubes, so it's not easy to ensure the section of the gear you want is actually running on the cable. motorcycle chain lube might help to lubricate the shafts.
Thanks for replying Ralph but I think uv slightly misunderstood. The wheelboxes are brand new but I was wondering if I could take the gearwheels off in order to gain access to the shafts. Its damn near impossible to lube the shafts with the gear on.
If its new send it back and have it replaced as they should be free to turn, Dont think they will come apart as they are swaged on. The only thing I can think of is to sit it in a tub of engine oil over night and see if that helps, or stick a battery drill on the shaft and see if it free's off.
as said above take/send it back, new item shouldn't need any work other than fitting it to the vehicle.
