duncmc Posted February 23, 2012 Share Posted February 23, 2012 Tonight I removed my headlining from my RRC, cleaned off the old stuff and got it ready for the new material from Woolies trim. I sprayed the headlining glue as per the instructions (this stuff http://www.woolies-trim.co.uk/p-1554-high-heat-resistant-aerosol-adhesive.aspx) and applied the new material. But is is not sticking, the glue just is not sticky. Has anyone else had this problem? Or what glue have other people used who have replaced their headlining material? I will give Woolies a ring in the morning and see what they say. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted February 23, 2012 Share Posted February 23, 2012 I did my headlining using the same supplier and the same aerosol glue. I found that i needed twice as much as expected to make it stick but its been in place for 2 summers now and outside in the hottest days we had last summer with no problems. The material is very absorbent and i think its a case of spraying enough onto the fabric so that that it exceeds the absorption of the material. This means in practice spraying lines of glue rather than trying to cover the whole area, otherwise you will need 10 cans! Quote Link to comment Share on other sites More sharing options...
DrRob Posted February 23, 2012 Share Posted February 23, 2012 http://forums.lr4x4.com/index.php?showtopic=44345&st=0&p=410717&hl=woolies&fromsearch=1entry410717 http://forums.lr4x4.com/index.php?showtopic=33322&st=0&p=323099&hl=woolies&fromsearch=1entry323099 just in case you haven't read already.......... Quote Link to comment Share on other sites More sharing options...
fozsug Posted February 23, 2012 Share Posted February 23, 2012 I used Dunlop S1922 spray contact adhesive available from Trade Grade Products 01202 822177 Quote Link to comment Share on other sites More sharing options...
duncmc Posted February 23, 2012 Author Share Posted February 23, 2012 I did my headlining using the same supplier and the same aerosol glue. I found that i needed twice as much as expected to make it stick but its been in place for 2 summers now and outside in the hottest days we had last summer with no problems. The material is very absorbent and i think its a case of spraying enough onto the fabric so that that it exceeds the absorption of the material. This means in practice spraying lines of glue rather than trying to cover the whole area, otherwise you will need 10 cans! Good to know that you used the same glue SteveRK and found you needed to use a lot of it. I recon I used about3/4 of the can and really think I'll have to get another can before having another go. http://forums.lr4x4....=1 http://forums.lr4x4....=1 just in case you haven't read already.......... Thank you DrRob, but yes I have read that last week. I used Dunlop S1922 spray contact adhesive available from Trade Grade Products 01202 822177 At least I can try this if I don't get anywhere with another coat of the same stuff. I also found that the material is only just wide enough even at 54". And the foam backing won't then go all the way to the edge like the original stuff did. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted February 24, 2012 Share Posted February 24, 2012 I got through 2 cans and could have used at least one more for the job. My brother did his disco roof lining before me and used 2 cans and did suffer from detachment when the weather got hot. I recommend getting some more cans and really lay it on until you can see it floating on the surface of the fabric. Quote Link to comment Share on other sites More sharing options...
reads90 Posted February 24, 2012 Share Posted February 24, 2012 One way we do it in flooring with the spray adhesive is to spray on both sides leave to dry a bit then stick them together but make sure you get them in the right place as it will stick straight away (null) Quote Link to comment Share on other sites More sharing options...
duncmc Posted February 25, 2012 Author Share Posted February 25, 2012 I have bought 2 new spray cans of glue this morning from a different source. (Same type of stuff but effective upto 90 degrees C instead.) So, I can have another go later. The new cans have much better instructions on them, including recommending getting the items to be stood in a 20 degree environment for a couple of hours first. Well, they have had a couple of days inside now! Quote Link to comment Share on other sites More sharing options...
SteveRK Posted February 25, 2012 Share Posted February 25, 2012 Sounds like a plan, I'm confident you will get a good result so long as you have enough adhesive sprayed on, its the sort of job you can only do once without having to rip it all out and start again from scratch so well worth taking extra trouble to get it right. Quote Link to comment Share on other sites More sharing options...
duncmc Posted February 29, 2012 Author Share Posted February 29, 2012 Just had another go at this, and with a LOT of glue (nearly 2 whole cans) it has stuck. Only problem is the new glue came out blue. Hopefully it will dry clear. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted February 29, 2012 Share Posted February 29, 2012 oh dear! i hope so too Quote Link to comment Share on other sites More sharing options...
