TJ101 Posted March 10, 2012 Share Posted March 10, 2012 Is their any difference between a 3.5 efi and carb dizzy ?? more or less the same vintage ? Thanks Quote Link to comment Share on other sites More sharing options...
bluespanner Posted March 10, 2012 Share Posted March 10, 2012 I would assume they would both be Lucas 35dlm8. my '92 carb engine has this,,and it uses the short rotor arm a la efi. Quote Link to comment Share on other sites More sharing options...
p76rangie Posted March 10, 2012 Share Posted March 10, 2012 They seemed to change their distributors every couple of years. I have a shed full of them and no 2 are the same. That said, they will all fit. It might be that the wiring is slightly different or that you cannot swap parts between them. Quote Link to comment Share on other sites More sharing options...
g&t Posted March 12, 2012 Share Posted March 12, 2012 They seemed to change their distributors every couple of years. I have a shed full of them and no 2 are the same. That said, they will all fit. It might be that the wiring is slightly different or that you cannot swap parts between them. The advance curve may be different as well(?) The high-comp. EFI was supposed to need 97 octane but my '87 will (according to the LR workshop manual) run on 94 but an '88 model should have '95. Confused? you will be! Quote Link to comment Share on other sites More sharing options...
