hissing sid Posted April 12, 2012 Share Posted April 12, 2012 After a heated discussion in the pub last night I need to ask a question. One of the lads seems to think that a 2 wheel drive Freelander TD4 Automatic is much more economical on Diesel than a 4 wheel drive version. Now logic tells me this is correct, but can someone confirm it please. I have been toying with the idea for quite a while but didn"t know whether there was anything to gain from doing it. Cheers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 12, 2012 Share Posted April 12, 2012 Much more is stretching it a bit unless the VCU is seized up. But yes, you'll see a bit of difference. Quote Link to comment Share on other sites More sharing options...
EggNChips Posted April 13, 2012 Share Posted April 13, 2012 Like FridgeFreezer said, it won't make a massive difference. The only bit that's not turning is the propshaft/VCU and that's not all that heavy in comparison to the rest of the car. Think around 2mpg of difference as a rough estimate. Quote Link to comment Share on other sites More sharing options...
nickcc Posted April 13, 2012 Share Posted April 13, 2012 Tried front wheel drive, when waiting for new VCU (and for me to be bothered to fit it) and found consumption about the same, the reason being due to faster acceleration and me having a heavier right foot. Quote Link to comment Share on other sites More sharing options...
RJF Posted April 13, 2012 Share Posted April 13, 2012 Like Nickcc, I ran 2wd whilst swapping VCU bearings. It did seem nippier and I got about 1-2mpg better economy, but that was only a short test and well within the error for such a short test. I found that it felt much more stable and planted when in 4wd. Rob. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 13, 2012 Share Posted April 13, 2012 I think the saving is not from having to rotate the prop but from the drag caused by the difference in gearing front:rear that makes the front "pull" the rear along. Quote Link to comment Share on other sites More sharing options...
