Drizz Posted May 7, 2012 Share Posted May 7, 2012 If fitting a Salisbury to a disco, what would you do with regards to props. Would you be able to mix and match with defender UJs or change the flange on the salisbury or would you need to custom make a prop? Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted May 7, 2012 Share Posted May 7, 2012 For a start your prop is going to need to be about 2" shorter to accomodate a Salisbury, you may be very lucky and find a 90 prop that will fit, you could try to source a 200Tdi disco prop and shorten that or as you say have a custom prop made. Quote Link to comment Share on other sites More sharing options...
Drizz Posted May 7, 2012 Author Share Posted May 7, 2012 Is the flange on the diff interchangeable do you know? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 7, 2012 Share Posted May 7, 2012 It can be removed & replaced like any other diff, but the salisbury is not to be dismantled unless you really have to as the pinion preload is set by a crushable spacer. You might find a prop off-the-shelf that fits, or just get propshaft clinic to make you one. Quote Link to comment Share on other sites More sharing options...
Drizz Posted May 7, 2012 Author Share Posted May 7, 2012 OK, thanks for youre help Quote Link to comment Share on other sites More sharing options...
Drizz Posted May 7, 2012 Author Share Posted May 7, 2012 Ive googled the prop clinic and it brings up a different company. Have they rebranded do you know? Quote Link to comment Share on other sites More sharing options...
