Trevorevans Posted May 22, 2012 Share Posted May 22, 2012 Hi I've run a search on this but have turned up nothing so far so am after some help/ ideas. I went out earlier this evening in the light and parked up at my destination, when I returned in the dark I jumped in started the truck and switched on the headlights, the blue main beam indicator illuminated on the dash so I pulled the lever back till it clicked but the main beam indicator remained on. I then looked up expecting to see bright lights but could not see very much at all and thought I had no lights, on getting out to check i found I only had dipped headlights. No matter what position the switch is in that's all I get is dipped beam no 'flashers' either but still the main beam indicator remains illuminated in both dipped and headlight positions. It seems also that there is a relay in the passenger footwell that clicks when I operate the stalk switch. As its dark and the neighbours won't be too happy if I'm out there knocking about in torchlight I am after a few ideas or at least a starting point for my investigations after work tomorrow. Thanks in advance. Trucks a 1998 300 tdi disco ES. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted May 22, 2012 Share Posted May 22, 2012 Do a search for Dim-dip relay not had experience of them but know they are problematic on some ages of Discoveries. They can be easily bypassed IIRC Quote Link to comment Share on other sites More sharing options...
fozsug Posted May 23, 2012 Share Posted May 23, 2012 I had similar but couldnt get of main beam and it was the stalk itself. Quote Link to comment Share on other sites More sharing options...
barriesheene Posted May 23, 2012 Share Posted May 23, 2012 I'd start with the relay. Just cos its clicking doesnt mean its making a good contact. Swap it with a good un and see what happens. You havnt got spots spliced in somewhere have you shorting out the main beam ??? just a thought. Quote Link to comment Share on other sites More sharing options...
