GW8IZR Posted June 10, 2012 Share Posted June 10, 2012 Has anyone had luck finding the rubber valve seat 2232660139 from a Girling G-Valve? TIA Regards Paul Quote Link to comment Share on other sites More sharing options...
western Posted June 10, 2012 Share Posted June 10, 2012 AFAIK these are a non-serviceable part, in other words if faulty or suspect just fit a new one. if yours is item 1 on page 592 http://www.retroanaconda.com/landrover/parts_books/90/7_brakes_fuel_air_exhaust_cool_heat_p581-718.pdf then there isn't a repair kit for it listed in the 90 parts book. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted June 10, 2012 Author Share Posted June 10, 2012 Hi Ralph, there is nothing complex in the unit and its perfectly serviceable *if* you can get the part. As its been used in many different vehicles its possible someone somewhere has the bits. Regards Paul Quote Link to comment Share on other sites More sharing options...
western Posted June 10, 2012 Share Posted June 10, 2012 a good motor factor might have a catologue showing the internal parts, not sure if the G valve is a Girling or Lockheed made item. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted June 10, 2012 Author Share Posted June 10, 2012 Girling - its a very simple but clever device and but for a 5/8" bit of rubber mine would be fine ;-) Quote Link to comment Share on other sites More sharing options...
