Stevie D Posted June 13, 2012 Share Posted June 13, 2012 Ok so I have set of vented discs for the front and new calipers, pads etc for the back of the project 300TDi XS Disco. It has ABS. Defender Vented - single pipe calipers seem to be a bit scarce and new are a bit out of my budget at the minute. Would prefer oem lockheed etc. I know that RR classic had a vented option albeit with the twin pipe arrangement - will these work with a T piece / two pipes from one feed, presumably the volume of brake fluid won't be much / any different as the defender units must have a similar hydraulic circuit internally? Are these smaller than the defender version? What about TD5 / Disco 2 stuff, I know the stub pattern is different, but what about the calipers - where these all vented, will the mounting bolts / pitch / offset etc be suitable - anybody done it? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2012 Share Posted June 13, 2012 FTC902 will fit Discovery front these are vented disc, same as used on Defenders & RRC.http://www.lrseries....h=FTC902&page=1 Front vented calipers for Discovery LH http://www.brit-car....php?xProd=91656 & RH http://www.brit-car....php?xProd=91653 or find a scrap 300Tdi Disco with vented front brakes, buy new disc & seal kit & refurbish the vented calipers have you scoured ebay for parts. Quote Link to comment Share on other sites More sharing options...
