disco_al Posted June 14, 2012 Share Posted June 14, 2012 As per title really. I could do with powering up my disco with the dash out to check the electrics. Now obviously the air bags are off, so if i reconnect now, then it'll tnrow a wobbler and put the airbag light on, if i unplug the the airbag ecu, will it be ok to power the ignition accessories up? Heater etc, to test them. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted June 14, 2012 Share Posted June 14, 2012 Not 100 % but if you disconnect battery , wait say 10 mins and then disconnect srs ecu the whole system will have gone dormant , and you should then be able to remove /refit system components following normal safe practices . Without the srs ecu the components will not function . and will not have a history if all reconnected properly before recoonecting srs ecu to powered down system and then powering up. Have a look on rave for definiteve advice HTSH E&OE Quote Link to comment Share on other sites More sharing options...
disco_al Posted June 14, 2012 Author Share Posted June 14, 2012 everythings been disconnected for about 2-3 weeks now as i've been welding the A pillars up, so no probs there - air bags are in the boot so, i should be ok to just unplug the ecu and power up - just wanted to make sure, as i've got to run some accessory circuits behind the dash, and with it removed it's a damn site easier to route them and make sure it all works first. cheers Quote Link to comment Share on other sites More sharing options...
disco_al Posted August 29, 2012 Author Share Posted August 29, 2012 just to clarify - in order to power up the electrical system without upsetting the airbag ecu, remove the yellow sheathed wire from the fuse box, as well as the corresponding fuse, and you can safely power up the electrical circuit without causing problems Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted August 29, 2012 Share Posted August 29, 2012 No,just disconnect the ECU - it will be fine,there is a shorting bar in the connector plug anyway.Make sure the airbag circuits are completely connected up before powering it back up or you will end up with the warning lamp on. Quote Link to comment Share on other sites More sharing options...
