Hybrid_From_Hell Posted June 27, 2012 Share Posted June 27, 2012 On a STANDARD Factory Disco 3.9 V or Serpentine and similarly 3.9 RR I am trying to work out what the "Orientation" is of the AFM on the Hotwire units I have this photo : I think this is a V Belt RR. Questions are : Is this an accurate position of the AFM and Air Filter Unit ? Are the positionings of these units the same on RR Disco V- belt and Serpentine ? Help ! Nige Quote Link to comment Share on other sites More sharing options...
duncmc Posted June 27, 2012 Share Posted June 27, 2012 That is a V belt engine in a RRC. It is also a left hand drive model! My right hand drive RRC also has a V belt 3.9 and the AFM looks to be in a very similar place. However mine might have been moved slightly to give a bit more room for the PLG vaporiser. I will post a picture when I get home. The factory fitted serp engine models have the plastic square air filter don't they? So the AFM could be in a different place, but you would think that the LR engineers would just have designed the box leaving everything else in the same place wouldn't you........oh hang on its LR we are talking about. Quote Link to comment Share on other sites More sharing options...
cosecon Posted June 27, 2012 Share Posted June 27, 2012 Googling I found: 1995 Range Rover 1993 Range Rover 1995 Discovery older 3.5 disco Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 27, 2012 Share Posted June 27, 2012 As Cosecon has shown, serpentine engines had the square plastic air filter box, whether RRC or Disco. AFM is the same way around in all instances. AFAIK it's the same model AFM. Quote Link to comment Share on other sites More sharing options...
task Posted June 27, 2012 Share Posted June 27, 2012 3AM that then changed to the 5AM AFM, the V-belt setup uses a metal "mount" bolted to the inner wing whereas the plastic air-box setup they introduced on serp engines is supported by the airbox. You can just see the mount and the AFM bolted to it in that photo. I can take more photos if you like? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 27, 2012 Author Share Posted June 27, 2012 Yippee Do The Pics showing the AFM flat top = level is great news, when I looked the only pic I had was "Canted" which would have made things trickier, I will go with the flat stylee for me ickle project ta muchly Nige Quote Link to comment Share on other sites More sharing options...
