Manxfreelander Posted July 9, 2012 Share Posted July 9, 2012 Hey guys I need your help I bought a 2000 freelander td4 Es I have noticed that when ur driving it the steering is fine and feels fine no stiffness at all when driving. It's only when the car was at idle the steering went really really heavy and it was like try to steer without the power steering when I looked at the power steering bottle it was below the min so I put some in but a bit too much in over the max line cos when I started it again and drove and did it all again the steering was still the same and when I looked at the bottle it had spilt some out over the top can anyone help cos this is really annoying me :/ Quote Link to comment Share on other sites More sharing options...
kiwi_110 Posted July 9, 2012 Share Posted July 9, 2012 Check your serpentine belt tension. The belt may be slipping on the PS pump at low revs. Ray. Quote Link to comment Share on other sites More sharing options...
Manxfreelander Posted July 9, 2012 Author Share Posted July 9, 2012 Hey thanks for the reply. Where do I find the ps pump and how do I tighten it and I take it there is only one belt to the pump ? Quote Link to comment Share on other sites More sharing options...
kiwi_110 Posted July 10, 2012 Share Posted July 10, 2012 PAS pump is on the drivers side of the engine as are other belt driven accessories like the Alternator, water pump, aircon pump. There is a single belt going around the pulleys for all the accessories and a tensioner that automatically keeps the appropriate tension on the belt. If the tensioner is stuffed or the belt too old, you may be getting slippage. Check the tech forum for details or download the RAVE manual. Ray. Quote Link to comment Share on other sites More sharing options...
Manxfreelander Posted July 10, 2012 Author Share Posted July 10, 2012 I have looked through but can't find anything where do I download the RAVE MANUAL from is there a link you can send me. I am new to land rover and 4x4 Thank you Quote Link to comment Share on other sites More sharing options...
western Posted July 10, 2012 Share Posted July 10, 2012 http://forums.lr4x4.com/index.php?showforum=34 try the 3rd link from top Quote Link to comment Share on other sites More sharing options...
defv890 Posted July 22, 2012 Share Posted July 22, 2012 Hi if the pas resoviour is at the correct level and with the engine on open the pas cap if u see lots of bubbles or foaming your pump as the culprit recommend changing the resoviour also as its the filter as well. Hope this helps Quote Link to comment Share on other sites More sharing options...
