petrolhead63 Posted August 1, 2012 Share Posted August 1, 2012 I have noticed a slight squeel as revs build up from about 2500 revs. I had not noticed it before but then its not heard with the radio on at all, staionary if you blip the engine quickly to about 4500rpm it squeels briefly until the revs drop back. I have changed oil to a fully synthetic as supplied in a full service kit from a decent supplier and also did the oil rotor/spinner, filters etc along with lots of suspension/brake work. Could this noise be turbo bearing? if so is it possible for me to overhaul it myself? Alternatively, what about the change of oil?? I wonder if the fully synthetic oil is not liked. Any thoughts received happily. Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted August 1, 2012 Share Posted August 1, 2012 I've got fully synthetic oil and it runs lovely, so it's not just that. The Turbo does kick in at around 2500 rpm so that seems relevant. No idea from there though, sorry! Dave Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted August 1, 2012 Share Posted August 1, 2012 I'll second the fully synthetic, just done the disco with it again and run the l200 on it too, no problems with either. I would look at the hoses to the turbo for splits/holes and check the actuator and its pipes before worrying about it being the actual turbo. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 1, 2012 Share Posted August 1, 2012 As above, the other thing I have seen on a few is a wailing baffle in the exhaust (due to being loose inside the silencer can). Nowt you can do about it except change the silencer, and it's not dangerous, but it can be bloody annoying! Quote Link to comment Share on other sites More sharing options...
Porny Posted August 2, 2012 Share Posted August 2, 2012 Check the front and rear exhaust manifold studs... Usually the back one that you can't see under the head shield... they have a habit of snapping when the manifold warps slightly. Ian Quote Link to comment Share on other sites More sharing options...
Julian Posted August 2, 2012 Share Posted August 2, 2012 I have noticed a slight squeel as revs build up from about 2500 revs. I had not noticed it before but then its not heard with the radio on at all, staionary if you blip the engine quickly to about 4500rpm it squeels briefly until the revs drop back. Any thoughts received happily. Alternator belt slipping. Julian. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 2, 2012 Share Posted August 2, 2012 Alternator belt slipping. Julian. Doubt it. Td5 has a polyvee belt which is unlikely to slip unless one of the ancilliaries like the alternator or PAS pump has seized, and the clouds of foul smelling smoke usually give it away! Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 3, 2012 Share Posted August 3, 2012 I vote for a warped exhaust manifold with a broken stud or two. Quote Link to comment Share on other sites More sharing options...
