JeffR Posted August 4, 2012 Share Posted August 4, 2012 Central locking is having a bit of a hissy fit on the rear door. I have a bit of a question regarding the solenoid, when you lock the doors, the plunger in the solenoid goes up, but does not stay up, that is it falls back ibto the body of the solenoid under gravity. Is this correct or is the solenoid goosed, vehicle is 1992 200tdi Cheers children Quote Link to comment Share on other sites More sharing options...
teabag Posted August 5, 2012 Share Posted August 5, 2012 That is one of the symptoms of a broken lock spring the door pin rising and then droping back down slightly, the actuator is in the door cavity not the lock. Quote Link to comment Share on other sites More sharing options...
Ziggymachine Posted August 6, 2012 Share Posted August 6, 2012 Yes have to agree, my rear door failed first so I got a set of 5 springs and Ive fitted 3 springs now rear door and 2 rear passenger ones fiddley job but only a 1 brew job Quote Link to comment Share on other sites More sharing options...
JeffR Posted August 7, 2012 Author Share Posted August 7, 2012 Well that is six hourd of my life I'll never get back - wretched little spring now replaced and centarl locking functioning , just got to do the other 4 springs next...... Thanks folks, suppose (given the cost of a new actuator) changing just the springs is the cheap option. Quote Link to comment Share on other sites More sharing options...
