gadget Posted August 4, 2012 Share Posted August 4, 2012 I'm trying to remove the ignition lock barrel from its housing. I can see that it is held in place by a pin, but I can't see a way to release the pin. Anyone know how to release the pin? Quote Link to comment Share on other sites More sharing options...
western Posted August 4, 2012 Share Posted August 4, 2012 have you tried pushing the pin inwards toward the barrel centre. Quote Link to comment Share on other sites More sharing options...
gadget Posted August 4, 2012 Author Share Posted August 4, 2012 The pin turns out to be some kind of security rivet. Compress the barrel in a vice to stop the pin spinning and then drill out with 5mm bit. The reason for removing it was to find out why the ignition lock had seized again. Turns out it's the last tumbler in the barrel that is worn and not siting properly when the key is in, along with debris in the barrel. Filed the last tumbler edge and cleaned everything up and it's back to working again. Quote Link to comment Share on other sites More sharing options...
western Posted August 4, 2012 Share Posted August 4, 2012 glad you sorted it, a no big cost fix, which we all like. Quote Link to comment Share on other sites More sharing options...
mahon257 Posted August 4, 2012 Share Posted August 4, 2012 we need a "like" button, on this forum... Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 8, 2012 Share Posted August 8, 2012 No we don't Quote Link to comment Share on other sites More sharing options...
