Heavy Duty Bumper - for td5 (2004)
Hi,
I am inheriting a 2004 td5 - 90 (lucky me !) ...
Is it possible to fit a heavy-duty military front bumper to this model ?.
The reason is I would like to use this bumper as I can fit a ball pin type towing hook to the centre bar - to allow me to shunt a couple of trailers, 'nose-on' into quite tight storage areas.
I have failed miserably in my attempt to back such trailers in - but have used the nose-towing method with great success during my military days....
Any help - greatly appreciated..
Thanks
Pete
or fit one to your existing bumper with a 10mm thick spreader plate on the inside, so you'd have this
bolts - drop plate with tow hitch fitted - bumper - spreader plate - nuts.
the military bumper is only slightly stronger in the centre around the tow pin. otherwise the fitting to chassis is exactly the same.
Indeed...calling it a 'stronger' bumper is a bit of a misnomer.....
I have a length of 3 x 1½" steel channel backing up the front tow balls on both Series 3's - plenty strong enough.
Are you sure you want it in the middle? I put Kettle's in the middle, but its very difficult to see past a caravan.
Excellent - many thanks for the replies...
Thanks ejp - will be for low loader/tranporter trailers - so will be able to see over most of them - no caravans or high box trailers as yet.
Thanks Western - do these come in a kit form ? - spreader etc...?
Happy - don't think it has Aircon.. will check.
Ron - is the D44 the galvised jobby...?
Thanks Again
Pete
bolts.nuts can be bought from a engineering supplier or a trailer parts supplier or any good motor spares shop, spreader plate can be made at home or from the same source as the bolts/trailer tow hitch.
