gadget Posted August 16, 2012 Share Posted August 16, 2012 Whilst moseying about the net I came across a coolant part PYB500040. It's a blanking plug that closes off the oil cooler outlet and was apparently fitted to Discovery TD5s after 2A736340 VIN. By blanking off the oil cooler it would mean that the steel pipe that runs around the rear of the engine and the fuel cooler plumbing can be removed completely. Anyone have a coolant diagram for the post 2A736340? I'd like to see what else they changed. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 18, 2012 Share Posted August 18, 2012 on the EU2 modells the oil cooler gets the coolant direcly from the rad and on EU3 from the EGR cooler Quote Link to comment Share on other sites More sharing options...
gadget Posted August 18, 2012 Author Share Posted August 18, 2012 Take a look at the flow arrows in the two diagrams. The flow is from the oil cooler to either the radiator or the EGR cooler. The oil cooler gets its supply from the block. I'm hoping that someone has the coolant diagram showing the oil cooler exit blocked off with PYB500040. Quote Link to comment Share on other sites More sharing options...
