nickdefender90 Posted August 18, 2012 Share Posted August 18, 2012 is there much of a difference between them will series 2a bulkhead fit a series 3. TIA Nick Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted August 18, 2012 Share Posted August 18, 2012 Yes but is the answer. Windscreen mounts are different - easiest to keep S2a windscreen with bulkhead - S3 ones are not on the end but the face of the bulkhead. Wiring will be different - S3 loom would need some adaption to fit - its wired for alternators and has fuses under the steering column. Heater - optional self contained units on S2a - S3 is integrated with plenum chamber/distribution box in black crash padding . Different door restrainers. Otherwise its the same size in critical places - floor panels are interchangeable - later S3 have different arrangement for clutch cover/transmission tunnel front - no fixed return panel - it screws on. Just about anything's better than that S3 black plastic! Are you getting rid of the S3 plastic grill at the same time? Quote Link to comment Share on other sites More sharing options...
RobotMan Posted August 21, 2012 Share Posted August 21, 2012 Don't waste a good 2A bulkhead on a 3. Sell it and buy a 3, as it's getting hard to find good 2 bulkheads now. Quote Link to comment Share on other sites More sharing options...
