Rear Cross Member Options
disco_al
My rear body crossmember is rusty - nothing unusual i hear you cry - what options are there? other than £140 on a new one, can i fabricate one from box section?
i know it's profiled to fit over the chassis at the back end, and i've got no problems with shaping it to fit, then closing it back in after.
otherwise it'll be try and salvage the one of my old disco (which is still quite solid) repair the body mounts (the only bit that has fell off it) and re use that one.
thoughts and suggestions please
Yep YRM. I did mine back in April and couldnt have been easier when it came to fitting the new YRM piece.
You know its only going to get worse when you start cutting out the rot so save yourself the unnecessary work.
