FridgeFreezer Posted September 17, 2012 Share Posted September 17, 2012 I'm in need of a throttle cable, defender-style, that's about 1.5m long by my vague wavings of the tape measure. There's a few promising prospects on brit-car such as NRC7607 but no length is given. This style is another option: NTC3460 I've had a search but can't see a note of the lengths of the various options anywhere, I was sure someone round here would've made a list by now Reason for the length is to get from pedal (well, duh!) to the nearside of the plenum as the new plenum's throttle linkage comes in from the nearside, would be really short if the car was LHD Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 17, 2012 Share Posted September 17, 2012 I used the throttle cable from a 50th anniversary Defender and all the linkage gubbins from a 4.6 plenum (which I will fit later). The throttle cable comes off the plenum toward the passenger side wing, loops back runs along the bulkhead and then down to the drivers footwell. As the 90 is currently in bits I will go and measure for you in a min. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 17, 2012 Share Posted September 17, 2012 Rubbish cameraphone images! Comes in at 6 feet long from the u-shaped end that attaches to the plenum linkage to the rubber bulkhead fitting at the other end. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 17, 2012 Author Share Posted September 17, 2012 That looks perfick! Would it be SBB104100? Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 17, 2012 Share Posted September 17, 2012 Not sure on exact part number but it was a weird one like that, will check when I get home this evening, unless anyone else jumps in first... Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 18, 2012 Share Posted September 18, 2012 Just checked through my emails and it looks like that was the part number I ordered Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 18, 2012 Author Share Posted September 18, 2012 Excellent, ta for that! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 18, 2012 Share Posted September 18, 2012 I used the cable that came with my engine (ex Disco 1 serpentine 3.9). Runs from pedal, has the correct fitting, bends around bulkhead under windscreen, then takes another turn above the heater box before connecting to linkage similar to Quagmire's picture. I can't tell you part numbers, just what it came from and that it does fit as required. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 18, 2012 Share Posted September 18, 2012 Quagmire - how is your air box mounted? Have you used 50th parts? Quote Link to comment Share on other sites More sharing options...
Quagmire Posted September 19, 2012 Share Posted September 19, 2012 Mickey - I looked into using 50th parts but prices were as you might guess a bit steep. Instead I have a Range Rover filter can mounted onto a piece of aluminium angle that bolts to the throttle cable assembly. Is a nice neat idea that my Dad came up with. I knew I wanted the filter arrangement to be similar to a 50th, he figured out how to do it! silicon hoses were off ebay, including the elbow that reduces from 80mm down. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 21, 2012 Share Posted September 21, 2012 That looks nice and tidy Will have to scour the bay for reducer hoses. The occasional lpg backfire has resulted in my intake hose being repaired with gaffer tape Quote Link to comment Share on other sites More sharing options...
fozsug Posted September 22, 2012 Share Posted September 22, 2012 Hyphose do reducer silicon hoses. Quote Link to comment Share on other sites More sharing options...
