TheRecklessEngineer Posted November 13, 2012 Share Posted November 13, 2012 I remember coming across this issue when I was building the relay boards for Nige. My solution was to bridge out the contacts at build time - might be something worth considering for the future Nige? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 13, 2012 Share Posted November 13, 2012 Maybe someone would post the LINK to the info and/or a diagram/picture for future use? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 13, 2012 Share Posted November 13, 2012 http://www.megamanual.com/ms2/IAC.htm#fidle Here you go, scroll down a bit. Quote Link to comment Share on other sites More sharing options...
trulyalya Posted December 1, 2012 Share Posted December 1, 2012 Laptom, when you mentioned MAP (35 or 39) - what was that? What are the usual MAP values at different RPMs? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 1, 2012 Share Posted December 1, 2012 trulaya - Here's a couple of shots from my 4.6, this is idling: And this is driving on the motorway at ~60mph (steady cruising): Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 1, 2012 Share Posted December 1, 2012 Just found this too, might be helpful - values are very approximate, every car is different. Quote Link to comment Share on other sites More sharing options...
trulyalya Posted December 3, 2012 Share Posted December 3, 2012 Thank you, FridgeFreezer! Remarkably, didn't find any meaningful dependency between the MAP readings and spark angle advance (probably, the scale is misleading). The second shot - moving uphill? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 4, 2012 Share Posted December 4, 2012 The second shot - moving uphill? Couldn't honestly tell you, it was a long time ago! Quote Link to comment Share on other sites More sharing options...
