Hybrid_From_Hell Posted September 7, 2006 Share Posted September 7, 2006 Ok If you have 8x16 mach 5s.................. I need help with 1 simple measurement............... Could you please measure and post up the measurement as follows : Placing a 16 inch bar acrosss the OUTSIDE of the rim face. Then place a tape measure - by hooking the tape measure on the INSIDE lip - (ie the part that meets and bolts to the hub) of the wheel centre and then Measure from the inside of the wheel centre to the outside edge of the front part of the rim Inchs or mm PLEASE ! Ta everso............ Nige Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 7, 2006 Share Posted September 7, 2006 112mm +/- 1mm (damn elastic tape steel rule! ) Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 7, 2006 Author Share Posted September 7, 2006 Ta Muchly Nige Quote Link to comment Share on other sites More sharing options...
richard-dangerous Posted September 7, 2006 Share Posted September 7, 2006 OkIf you have 8x16 mach 5s.................. I need help with 1 simple measurement............... Could you please measure and post up the measurement as follows : Placing a 16 inch bar acrosss the OUTSIDE of the rim face. Then place a tape measure - by hooking the tape measure on the INSIDE lip - (ie the part that meets and bolts to the hub) of the wheel centre and then Measure from the inside of the wheel centre to the outside edge of the front part of the rim Inchs or mm PLEASE ! Ta everso............ Nige OK i have just measured mine up and 111mm, but i think they may come in different offsets, mine were from devon 4x4 and were ordered for a standard 90 so they should be ok, hope this helps. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 7, 2006 Author Share Posted September 7, 2006 I allow you both +/- 1mm Ta muchly again, not the easiest thing to measure I know Nige Quote Link to comment Share on other sites More sharing options...
nas90 Posted September 7, 2006 Share Posted September 7, 2006 I allow you both +/- 1mm Ta muchly again, not the easiest thing to measure I know Nige When I bought my Mach V's first thing Matt asked was what off-set do you want? Think you will find he makes a lot to order, or did a few years ago Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 7, 2006 Share Posted September 7, 2006 Mine are just under 90mm. Going imperial mine are 3.5 inches compared with 4.5 inches from the others above. Quote Link to comment Share on other sites More sharing options...
