HoSS Posted September 19, 2006 Share Posted September 19, 2006 Does anyone know the nominal fuel rail pressure on the V8 Efi's Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 19, 2006 Share Posted September 19, 2006 Does anyone know the nominal fuel rail pressure on the V8 Efi's Around 30-32psi without engine running, engine running just a tad lower, less than 28 and you will have problems, more than 36 psi same Nige Quote Link to comment Share on other sites More sharing options...
HoSS Posted September 19, 2006 Author Share Posted September 19, 2006 cheers. actually found it on RAVE - 2.4 - 2.6 bar (34 - 38 PSI ish) Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted September 19, 2006 Share Posted September 19, 2006 cheers.actually found it on RAVE - 2.4 - 2.6 bar (34 - 38 PSI ish) Yes, that’s correct……… 38psi at anything above tickover………. At tick over the vacuum operated pressure regulator drops the pressure by 0.5 bar (7ish psi) . From experience I can tell you that if you go much over 45psi the injectors tend to drip when closed …….. this causes popping in the exhaust. The aftermarket adjustable regulators that come pre-adjusted should be checked ……… mine was set at 55psi. Ian Quote Link to comment Share on other sites More sharing options...
