Front windscreen washers
DrRob
Lost front windscreen and headlight washers on '93 Classic. Same set up as Disco I presume. One pump for screen and one pump for headlights. Rear screen has separate pump and that works ok.
Checked fuse - all ok.
No pump sounds heard when push end of stalk.
Anybody else been had this?
Any pointers appreciated.......my thoughts are the stalk switch as neither pump works........
Ta
Rob
I had a pump stop spinning once so i removed it and turned the impeller to clear the blockage and then refitted the pump and it worked from then on. When you have access to the pumps you will then be able to test if the 12v supply is reaching the pump. Could well be the staik, you will have to test it with a meter.
