DIZZY Posted March 22, 2013 Share Posted March 22, 2013 hi i have just had the front diff replaced at a land rover specialist and since having it done i am experiencing a violent shake/vibration its not apparent at the same speeds i can do 40mph and it shakes like mad then if i ease off it goes then doesnt come back till i hit 50-55mph but it never happens below 40mph i did notice i was doing 40mph along a straight tonight and it was really bad as i went round a left hand bend keeping the same speed it dissapered, any help would be appreciated Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted March 22, 2013 Share Posted March 22, 2013 hi i would check the panhard rod make sure it is nice and tight as they might have forgot to tighten it up hth brian Quote Link to comment Share on other sites More sharing options...
DIZZY Posted March 22, 2013 Author Share Posted March 22, 2013 would they of took that off then to do the diff? Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted March 23, 2013 Share Posted March 23, 2013 yes they might have Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 23, 2013 Share Posted March 23, 2013 Have you check the the UJ's on the prop shaft? Mav Quote Link to comment Share on other sites More sharing options...
C18RCH Posted March 25, 2013 Share Posted March 25, 2013 Have you check the the UJ's on the prop shaft?Mav That would get my vote too. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 25, 2013 Share Posted March 25, 2013 Bad prop or bad diff. Quote Link to comment Share on other sites More sharing options...
lansalot Posted March 25, 2013 Share Posted March 25, 2013 Until I had this rock-solid tight (had to drill out and enlarge the hole a little), my defender was lethal. That sorted it tho. A Quote Link to comment Share on other sites More sharing options...
