porsche Posted March 26, 2013 Share Posted March 26, 2013 Does anyone know if , the radiator surround on a defender has mounting blocks on the underside like the discovery one , if not is it possible to cut the ones of the disco one and drill holes for mounting rubber , I have fitted everything but think the rad and intercooler sitting a little high as not sure if bonnet closing down enough, the surround and rad where from my old disco going into the new 90 . Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 26, 2013 Share Posted March 26, 2013 If I remember correctly one has to cut the mounts down on the chassis when using the Disco rad/frame/etc. in a 90/110 as it sits slightly higher without doing so. Just pins into the rubber mounts in the chassis as far as I know, same as the Disco - save for the height difference as above. Quote Link to comment Share on other sites More sharing options...
porsche Posted March 26, 2013 Author Share Posted March 26, 2013 so could i just cut the brackets off the surround rather than butcher brand new chassis / Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 26, 2013 Share Posted March 26, 2013 I'm not sure, possibly. I'm not familiar with Disco rad frames. See this thread: http://forums.lr4x4.com/index.php?showtopic=2394 It may answer your question. You can see the mounts being cut down. Quote Link to comment Share on other sites More sharing options...
