DAN82SED Posted April 3, 2013 Share Posted April 3, 2013 I want to swap my 200tdi front axle for a 300 disco because both the diff and cvs have had it. I've read it is a pretty straight forward swap but what I've noticed is how close the narrow radius arms to the chassis rails on mine. Would fitting the wider arms off the disco not foul on the chassis? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 3, 2013 Share Posted April 3, 2013 The chassis mounting points are the same on both models. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 3, 2013 Share Posted April 3, 2013 Shouldn't do, it's the axle end that is wider, not the chassis end. You will need the wider arms to go with the 300TDI axle. Quote Link to comment Share on other sites More sharing options...
