scottwilson1912 Posted May 7, 2013 Share Posted May 7, 2013 Hello all So MOT time is just 2 weeks away and close inspection of my old 300tdi i have found a fist size hole in the rear off side wheel arch right in the top and there a square bit of structural box section on show....Obviously this looks carp and being so close to the seat belt mount its bound to fail, what do i do????....Itd be a pig to try and weld up in there any suggestions?.......Help!!!!!!! Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted May 7, 2013 Share Posted May 7, 2013 If you have a mig fix it, then lash plenty of what ever you use to stave of rust with. You know you want to ;-) Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 7, 2013 Share Posted May 7, 2013 It is a pig to fix, only cure though is cut it out and rebuilt if you want it to last. Quote Link to comment Share on other sites More sharing options...
scottwilson1912 Posted May 7, 2013 Author Share Posted May 7, 2013 Cheers for the replies chaps....Unfortunately ive only got a stick welder at home ive got mig at work but cant use it on my disco.......im sure even with small rods itd just blow holes through any repair sections i bought Quote Link to comment Share on other sites More sharing options...
disco_al Posted May 8, 2013 Share Posted May 8, 2013 get a pic up, that'll help. new arches can be had for about £35 quid, and aren't too difficult to fit think they are held on with about 4 spot welds and a bolt into the quarter panel at the top Quote Link to comment Share on other sites More sharing options...
