Darren Roberts Posted May 9, 2013 Share Posted May 9, 2013 Guys, I had to remove the offside rear seatbelt from the C-Pillar to reinstall the fuel filler into my bobtail. The belt has retracted right in and now refuses to come back out - making re-fitment of the seat belt impossible...... Any ideas on how to get the belt to come out again...... cheers Darren Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted May 9, 2013 Share Posted May 9, 2013 I had this with one of mine, it relies on a ball bearing dropping in and out so make sure you have it the right way up whilst your trying to pull it out. If that doesn't work you can take the plastic end cap off and release the mechanism, you'll probably break some of the clips though. Mine still went on ok but if its too lose you might have to glue it on. Quote Link to comment Share on other sites More sharing options...
Darren Roberts Posted May 9, 2013 Author Share Posted May 9, 2013 Hi Cynic-Al, Got it to draw out using the technique you mentioned - orientated to the same direction it would be mounted on c pillar and after about 10 minutes of fiddling finally came loose. Fortunately I didn't have to resort to taking the end caps off. cheers Darren Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted May 9, 2013 Share Posted May 9, 2013 Glad you fixed it! Quote Link to comment Share on other sites More sharing options...
