muddy4x4xfar Posted May 10, 2013 Share Posted May 10, 2013 hi all again. i have a borg warner transfer box on a td5 110 defender . but unsure as to whether the standard propshafts will fit an just wanted to check before going out and buying them.? thanks for any help guys as always Quote Link to comment Share on other sites More sharing options...
Dave W Posted May 10, 2013 Share Posted May 10, 2013 No, it won't. The BW transfer box has a shorter nose so the front prop shaft is a few inches longer. The rear prop shaft should still fit. Having said that, that's from my own experience with changing from LT230 to BW, I've had conversations with other people who have said that on theirs the rear prop was different ! If I were you I'd take a tape measure to it and if you don't have the original prop shafts try and find another vehicle to measure Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 10, 2013 Share Posted May 10, 2013 I seem to remember having to swap the front prop for the one from the engine/g-box/t-box donor LSE. I think the back one was OK. Quote Link to comment Share on other sites More sharing options...
