Simon_CSK Posted May 25, 2013 Share Posted May 25, 2013 As the title says. I am guessing that the two are not connected at this stage. The water in the reservoir has turned black and I suspect that this is blow back from the cylinders. This could mean that I will put my good block in it but what are the likely causes of the miss fire? Quote Link to comment Share on other sites More sharing options...
rocksteady Posted May 25, 2013 Share Posted May 25, 2013 Hi there, have a look at the spark plugs. If you have one that looks like it has been steam cleaned! Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 26, 2013 Share Posted May 26, 2013 Could be related, bad running could cause overheating, or overheating could cause bad running. Look at the plugs, do a pressure test with the plugs out, and I guess you'll find out. Is it smoking, is there oil in the water or water in the oil? Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 26, 2013 Author Share Posted May 26, 2013 Could be related, bad running could cause overheating, or overheating could cause bad running. Look at the plugs, do a pressure test with the plugs out, and I guess you'll find out.Is it smoking, is there oil in the water or water in the oil? No smoke and minimal oil loss. Water black but no sludge not checked the oil yet. Will do tomorrow. Quote Link to comment Share on other sites More sharing options...
