evanmc Posted June 7, 2013 Share Posted June 7, 2013 1985 110 I'm replacing my clutch slave cylinder and I can't seem to push the new one in -- I can get it partially in, but I can't get enough leverage to push it in all the way. The old one was certainly tight and I struggled a bit to get it off... Any ideas? Thanks, -Evan- Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted June 7, 2013 Share Posted June 7, 2013 The new piston get stuck up with grease... I had to push the piston in with a screw driver. hope this helps. Cheers, mike Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted June 7, 2013 Share Posted June 7, 2013 There's not (a bit of) the rubber end of an old one stuck in the hole? (I once put an oil filter on with the old rubber gasket still stuck to the engine mating face. The oil spray on start up was spectacular.) Quote Link to comment Share on other sites More sharing options...
SmasherWebbs Posted June 10, 2013 Share Posted June 10, 2013 If you can find a long bolt or stud you can line it up and start pulling the slave in then catch the original bolts. Had the same issue doing mine last month. Also make sure the plastic cap is off and air and oil can escape as you pull it up make sure your not making life hard work. Quote Link to comment Share on other sites More sharing options...
