Bluemoon Posted July 6, 2013 Share Posted July 6, 2013 Does anyone know what the M+S and a zero with a diagonal line flashing on the dashboard means, also the engine will not start, but has been sat for a year or two, cheers Brian Quote Link to comment Share on other sites More sharing options...
mudmagnet Posted July 6, 2013 Share Posted July 6, 2013 M and s are the gearbox mode lights for an auto box there is a button on the gear lever surround that has mode on it I had these flashing on mine and despite fears of a gearbox problem it turned out to be a battery that didn't hold sufficient charge Quote Link to comment Share on other sites More sharing options...
dave88sw Posted July 6, 2013 Share Posted July 6, 2013 These lights will flash when you have a fault with the xyz/position switch on the gearbox. You say the car won't start, will it crank? If not, the 2 problems may well be related as the switch may not be telling the car that it is in park. Is the gear you are in displayed in the speedo? It should say P,R,N,D etc dependent on which gear you select. Quote Link to comment Share on other sites More sharing options...
Bingy Posted July 7, 2013 Share Posted July 7, 2013 I had the flashing 0 with a diagonal line through it flashing next to the mileometr reading on the dash. After a lot of searching, the local indie finally located the problem of a burnt out fusebox under the dash due to water running down the cables. You need to take the fuse box out and look at rear as some of the components on it are only visible then. The fusebox looked fine from the front. Needless to say i dont use that ( or any other garage any more) I think it means that the BCEM unit is/has malfunctioned, but on mine it was because it couldnt get the correct power due to the fusebox. HTSH Quote Link to comment Share on other sites More sharing options...
