Pheonix Posted July 17, 2013 Share Posted July 17, 2013 Hi Can anyone advise what the clear material is called that is glued to the doors of the Disco? This is the sheet that is visable once the door card hhas been removered and acts as a protection agaionst condensation. Also what the name of the gl;ue type substance is and weher can both of these items be bought from? Cheers Quote Link to comment Share on other sites More sharing options...
SPendrey Posted July 17, 2013 Share Posted July 17, 2013 These are referred to as "water curtains" on Microcat... RHS is BTR7134, LHS is BTR7135. A quick search on Google for those part numbers revealed a number of sites that carried them at one time or other, but don't appear to today. As for the adhesive, I don't know, but I would suspect something like Sikaflex would suffice. I used this to stick back the membrane, and good old gaffer tape to repair any tears in it. Quote Link to comment Share on other sites More sharing options...
Pheonix Posted July 17, 2013 Author Share Posted July 17, 2013 HiMany thanks Would you know what ,the material is to manufacture the actual door cards are called? Rgerads Quote Link to comment Share on other sites More sharing options...
qwakers Posted July 17, 2013 Share Posted July 17, 2013 this would suffice. http://www.ebay.co.uk/itm/5m-Blue-Polythene-Sheeting-Tubing-Plastic-Sheet-Roll-1275mm-2550mm-wide-/181171591420?pt=UK_Packaging_Materials&hash=item2a2eab18fc Quote Link to comment Share on other sites More sharing options...
streaky Posted July 31, 2013 Share Posted July 31, 2013 HiMany thanks Would you know what ,the material is to manufacture the actual door cards are called? Rgerads It's just fiber board isn't it? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted July 31, 2013 Share Posted July 31, 2013 Old stylee door cards aren't much more than thin hardboard, covered in a vinyl material. However hardboard isn't that resistant to life in a landy, especially from a moisture point of view. A more modern material that may suit if you want to make your own trim panels, would be Foamex board that is used for sign making. This is pretty impervious to water. As for the moisture curtain, any reasonably tough polythene sheeting would do.The adhesive stuff they use reminds me of Dum Dum putty, but I think it's a bit stickier than that. Gaffer tape does the job pretty well though. Quote Link to comment Share on other sites More sharing options...
