Blanco Posted August 6, 2013 Share Posted August 6, 2013 Following recent alternator trouble, I was on the motorway and driving on the last dregs of the battery, by the time I got off and into Norauto (sort of French Halfords) the dashboard had completely shut down, clocks, warning lights, absolutely everything. A new battery sorted the problem and got me home but now the LCD panel that records the kilometres just flashes all the time, I have tried plugging in my old Nanocom one to see if there is a related fault code but if there is I can't find it, I have cleared the fault codes that were on the ECU, but its still flashing away. Anyone come across this before?? All suggestions gratefully received. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 7, 2013 Share Posted August 7, 2013 Yes. From memory it shows a mismatch between the odometer reading and the mileage reading stored in the BCU. It normally happens as an alert that a new odo has been fitted and the figures don't match, but it could be a by-product of your electrical issues if communications were lost when you are driving. There is a process to re-sync the two (the odo reads the mileage out of the BCU) but it is many years since I did it and I can't recall if it is pressing 8 buttons standing on your head and twiddling your left ear, or whether you need a diagnostic computer - I think probably the latter. It'll probably need to be something better than a Nanocom though. It might tell you the procedure in the RAVE manuals but I don't have them installed at present. Quote Link to comment Share on other sites More sharing options...
Blanco Posted August 13, 2013 Author Share Posted August 13, 2013 Thanks BM, I'll have to find where I put my Rave disc , (having tried left and right ears!) . Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted August 17, 2013 Share Posted August 17, 2013 It needs to be rematched through a nanocom or similar as just had mine done due to changing instrument pack Rob Quote Link to comment Share on other sites More sharing options...
