disco_al Posted September 12, 2013 Share Posted September 12, 2013 I'm having problems  since getting blue back on the road, it's as if she's been possessed by some malevolent spirit. Sunday the head gasket went, so did that Monday (3.5 hours start to finish), since then I've had a problem with the power. When you hit 3k rpm, the engine dies, as in loss of power, and the boost drops off as well. Accompanied with this I can see quite a lot of blueish smoke coming out of the exhaust. Under 3k she's fine. I've changed the lift pump, turbo and I fitted a known good head as I would rather get the one removed checked before using it again. The sedimentor is clean (cleaned it last week while building up the chassis) and has been checked just in case. There was a slight drip from the spindle seal on the pump last week, which stopped after a day or two. Other than this annoying problem, she's running fine. Could it be the leak on the IP is letting air in under load (even though it's not dripping any more) or should I consider changing the injectors (I have 2 spare sets) in case one is faulty? Sent from my GT-I9300 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Tanuki Posted September 12, 2013 Share Posted September 12, 2013 Check all the hoses on the air-path aircleaner->turbo->intercooler->intake-manifold. Sometimes they delaminate internally and can suck flat under turbo-boost, restricting air inflow. Sometimes they split - then all your boost-pressure escapes! Quote Link to comment Share on other sites More sharing options...
disco_al Posted September 12, 2013 Author Share Posted September 12, 2013 Silicone and stainless hoses, already checked them today. Quote Link to comment Share on other sites More sharing options...
Challo Posted September 13, 2013 Share Posted September 13, 2013 Check the throttle cable. I had similar problem and it turned out to be the locknut for the cable at the injection pump end had failed. Quote Link to comment Share on other sites More sharing options...
disco_al Posted September 13, 2013 Author Share Posted September 13, 2013 Not the cable unfortunately. It does it if you operate the pump by hand as well Quote Link to comment Share on other sites More sharing options...
