Head pressure testing
ejparrott
More out of interest than anything else, but what pressure are heads normally tested at when they go for rebuild?
I'm a boiler tester for the Rugby Model Engineering Society, so I know a bit about pressure testing, and I got thinking about it the other day. For the most part leaks don't show until around the 50PSI mark - many boilers have 'failed' above this, but it occurs to me that the water jacket in say a 200TDi is only 15psi? and yet the cylinder areas so around the valve seats, is subject to compression and explosion and at what pressure??!! There's also the core plugs which fail at over pressure do they not?
