Reiny Posted November 3, 2013 Share Posted November 3, 2013 My fuel gauge has died suddenly. I was driving and suddenly, the gauge just went dead. Low fuel level light is still working though. What do I check first? I have checked the connections on the sending unit and all seems to be in place. Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted November 3, 2013 Share Posted November 3, 2013 Hi Reiny! I don't know if this is an 'urban myth' but I was told the fuel and temp gauges are the same but with a different face....I tried swapping them in my '89 110 when my fuel gauge failed.....And it worked! Quote Link to comment Share on other sites More sharing options...
PaddyMac Posted November 3, 2013 Share Posted November 3, 2013 Hi, If you checked that the low level light on the dash is working by letting the fuel run low and watch the light come on (rather than the inital startup test to show it lights) then I would be under the impression that the sender has nothing wrong with it. I would test the elec block at the back of the fuel gauge with a multi-meter to see if it's getting power and if it is then persume the gauge itself is faulty. Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted November 3, 2013 Share Posted November 3, 2013 On my 300tdi mine stopped working, I removed one of the little green/black wires on the back end and it started working, taped up the loose wire and carried on like that. Quote Link to comment Share on other sites More sharing options...
Reiny Posted November 4, 2013 Author Share Posted November 4, 2013 Thanks for your replies. I know that the low level light is working because I had very little fuel left in the tank when the gauge died. In fact I was on the way to fill the tank. I shall have to get an electrician to check the rest out as vehicle electrics are a dark science to me. The area behind the instrument panel is a no-go area. Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted November 4, 2013 Share Posted November 4, 2013 Fair comment Reiny! let us know the result? Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted November 4, 2013 Share Posted November 4, 2013 in my td5 one of the wires that goes to the gauge was crystallized and got broken Quote Link to comment Share on other sites More sharing options...
Reiny Posted November 5, 2013 Author Share Posted November 5, 2013 It was the sender unit. Quick test.... Removed green wire and black wire, touched the 2 together and the gauge responded. Need to find a spare 10 minutes to replace it. Quote Link to comment Share on other sites More sharing options...
