muddyplugger Posted October 8, 2006 Share Posted October 8, 2006 I was surprised today that when I turned to full lock the battery warning light came on! I did it either lock too. I suspected loose alternator belt, but it seemed ok, the alternator is only a month old too! A quick diagnostic when at full lock of revving engine did not change the light. How wierd is that? (1989 Defender, Tdi conversion) Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 Can't be related, sounds like a duff alternator, is the light on when engine is at idle ? is the light on with ignition & engine off/keys out off ignition ? if Yes to either the Alternator is faulty Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 8, 2006 Author Share Posted October 8, 2006 Cheers Western, but no to both! Everything else is otherwise fine! And I'm not drunk either! Definate battery warning light at the end of each full lock. Move off full lock and it goes out. Maybe that things will slowly get worse over this week and it may be the alternator is duff? Quote Link to comment Share on other sites More sharing options...
Andy Posted October 8, 2006 Share Posted October 8, 2006 checked BOTH drivebelts are tight? i had this ages ago on my disco Tdi. yes the alternator belt was tight, but the fan belt was loose & as on the disco lump (dunno defenders) the steering pump is driven by the fan belt & then drives the alternator belt it caused the light to go on. Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 Cheers Western, but no to both! Everything else is otherwise fine! And I'm not drunk either! Definate battery warning light at the end of each full lock. Move off full lock and it goes out. Maybe that things will slowly get worse over this week and it may be the alternator is duff? Check the alternator/power steering pump mounting to engine block bolts, sounds as though the mounting is moving when the pump is working hard & could be twisting the mount & affecting the Alt's wiring/output. can't think of anything else. Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 checked BOTH drivebelts are tight? i had this ages ago on my disco Tdi. yes the alternator belt was tight, but the fan belt was loose & as on the disco lump (dunno defenders) the steering pump is driven by the fan belt & then drives the alternator belt it caused the light to go on. Defender 200Tdi has a seperate belt for the power steering pump, Alt belt also drives the fan/water pump. Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 8, 2006 Author Share Posted October 8, 2006 ah ha! You could have something there! NB: is a disco 200Tdi under the bonnet (oops wrong forum?) Both belts I did not check, but now its too dark, I'm in my lounge pants and have bottle of wine to demolish! B) I will update you with those two suggestions, thanks guys!!! Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 8, 2006 Share Posted October 8, 2006 it will Be slipping belt for sure, i find if u can turn the engine over by turning the alternator pulley its tight enough, although that might be more difficult on a diesel Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 ah ha! You could have something there! NB: is a disco 200Tdi under the bonnet (oops wrong forum?) Both belts I did not check, but now its too dark, I'm in my lounge pants and have bottle of wine to demolish! B) I will update you with those two suggestions, thanks guys!!! OOps wrong forum --- I'll let you off, probably get more answers here Lounge pants ------ OOOOOOOOO get you, Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 8, 2006 Author Share Posted October 8, 2006 Lounge pants ------ OOOOOOOOO get you, Hey! These are very special lounge pants! Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 Hey! These are very special lounge pants! go on then, I'll fall for it, why are they 'very special' ?????? Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 8, 2006 Author Share Posted October 8, 2006 Ok, you called my bluff, you win. But for your amusement here they are..... Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2006 Share Posted October 8, 2006 hope their comfortable Quote Link to comment Share on other sites More sharing options...
Mark Posted October 8, 2006 Share Posted October 8, 2006 That Looks like the kitchen, not the lounge.... Are you sure they are not multi-room pants? Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2006 Share Posted October 9, 2006 That Looks like the kitchen, not the lounge.... Are you sure they are not multi-room pants? Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted October 9, 2006 Author Share Posted October 9, 2006 I'm back with my 'muti-room pants' [which has now a copyright] and the cause of the battery warning light and PAS is indeed a slack belt! Much like my pants! B) Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2006 Share Posted October 9, 2006 I'm back with my 'muti-room pants' [which has now a copyright] and the cause of the battery warning light and PAS is indeed a slack belt! Much like my pants! B) Great reply & a result too so are we going to see these 'multi room pants' on sale via the forum with discount for members Quote Link to comment Share on other sites More sharing options...
