JeffR Posted November 14, 2013 Share Posted November 14, 2013 The sliding heater fan switch on my 200Tdi is only working as and when it's feeling like it. A :does anyone have a part number? B: How much of a git is it to change? C can I replace it with an alternative? Quote Link to comment Share on other sites More sharing options...
Nigelw Posted November 14, 2013 Share Posted November 14, 2013 Jeff I had an issue to resolve on a friends blower switch, it was a loose contact pin on the back of the switch. This is the main power into the switch and it was fixed with just a tap with a center punch on the pin to re-secure the tab. Certainly worth a look and you will need to remove it any way. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted November 14, 2013 Share Posted November 14, 2013 Part number should be PRC5436 for models without airco. Quote Link to comment Share on other sites More sharing options...
JeffR Posted November 15, 2013 Author Share Posted November 15, 2013 cheers Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 15, 2013 Share Posted November 15, 2013 Also worth checking is the resistor-thingy that reduces the power to the motor to give the different speeds: these are well known to fail in interesting ways. If you're lucky they fail 'hard' and you get only full-speed; sometimes they go intermittent and then you get a random mix of usable speeds depending on the day of the week, your mother's cat's star-sign and the instantaneous value of the Dow-Jones index. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted November 15, 2013 Share Posted November 15, 2013 There are resistor packs available as an upgrade too, see how you get on with the switch first an if needed I will try and find a way to sort resistor pack without removing the entire dash! Quote Link to comment Share on other sites More sharing options...
Ebojonson Posted November 27, 2013 Share Posted November 27, 2013 This explains alot im onto full speed only and hot air when it wants (crusing @60) soon as you slow down it gets cold again. Im guessing the thermostat jammed open but im due buying one Quote Link to comment Share on other sites More sharing options...
