edwardatherton Posted October 9, 2006 Share Posted October 9, 2006 What exactly is involved in converting to 11-inch on the front. Is it a case of removing hub etc, replacing backplate/drum with 11-inch type, the refitting original hub, or do I need to fit the LWB hubs as well? I'm not bothered about pipework at the moment as I'm not doing the job right now, just stripping a LWB axle and don't want to throw away bits I might need! BTW, anyone want the case/halfshafts/diff? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 9, 2006 Share Posted October 9, 2006 Just replace the backplate Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 9, 2006 Share Posted October 9, 2006 Just replace the backplate & the drums, shoes, cylinders, pull off springs. Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted October 9, 2006 Author Share Posted October 9, 2006 So I can replace the 88" S1 hubs (with the double-ended wheelnuts) so it looks right from the outside then? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 9, 2006 Share Posted October 9, 2006 & the drums, shoes, cylinders, pull off springs. Obviously, I was just replying to the question in the original post Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 10, 2006 Share Posted October 10, 2006 i would be tempted to use the later hubs too, the hole size for the wheel studs will be 16mm on the drums from a late lwb ser3, the double ended nut type will be at 9/16 which will be loose, either that or buy early 2a lwb drums which should be 9/16 also Quote Link to comment Share on other sites More sharing options...
