defender side panels
Unbolt along top side, you'll find bolts along roof where roof meets side panels, and then unbolt at base, both ends and rear corner, three bolts in total at bottom, then slide sides out whilst supporting roof, and then slide new sides with windows in
The cut line on my existing defenders blind spot masai side panel starts 80mm forward of the normal cut line, i want to fit standard side windows and thought of swapping the side panels but have had a second thought.
What your opinion of fitting the side windows using the existing cut line which starts at the forward lower mounting bracket do you think this acceptable
Any views welcome ta
