Wes Posted December 6, 2013 Share Posted December 6, 2013 Hi all. The High / Low ratio warning light is not showing on the dash of my Disco 2. The High / Low range works perfectly so am assuming its either the bulb gone or a problem with the acuator on the gearbox. Is the actuator accessible from under the vehicle or do I need to remove the trim inside? Also how easy is it to remove the dash panel to check the bulb? Still waiting for my workshop manual to arrive. Cheers, Wes. Quote Link to comment Share on other sites More sharing options...
Divster Posted December 6, 2013 Share Posted December 6, 2013 Wes, there is no high/low warning light on a D2. There may be a warning light for the centre diff lock if you have one installed or have made aftermarket alterations Quote Link to comment Share on other sites More sharing options...
Wes Posted December 7, 2013 Author Share Posted December 7, 2013 Hi Divster. Thanks for reply. Was just going by the handbook which shows a high/low warning light and the symbol is on the dash but there is no light behind it. Wes Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 12, 2013 Share Posted December 12, 2013 you make some confusion IMO cos as said there's no such warning light...which one you mean from the attachment Quote Link to comment Share on other sites More sharing options...
