bigstevemex Posted December 17, 2013 Share Posted December 17, 2013 Good morning all.i wonder if this has happened to anyone else my 110 has lost reverse.it goes in but no drive all other gears ok. Does anyone have any thoughts please? Thanks in advance Steve. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted December 17, 2013 Share Posted December 17, 2013 I had this problem once and it turned out to be the reverse light switch had moved inwards and was just physically preventing me from engaging reverse. Could it be that simple? Cheers Peter Quote Link to comment Share on other sites More sharing options...
ashtrans Posted December 17, 2013 Share Posted December 17, 2013 Hi, A couple of questions : Do you have an overdrive ? Have you also lost 5th ? Dave Quote Link to comment Share on other sites More sharing options...
bigstevemex Posted December 18, 2013 Author Share Posted December 18, 2013 hi dave no overdrive 5th is still working and i drove it home thanks steve. Quote Link to comment Share on other sites More sharing options...
ashtrans Posted December 18, 2013 Share Posted December 18, 2013 reverse is made in 2 parts and beam welded together, I would think the weld has broke, ie it selects fine but has no drive, the cone clutches in the GKN overdrives also fail which loose reverse which is why I asked, if you lose 5th as well then the layshaft has sheared Dave Quote Link to comment Share on other sites More sharing options...
